240_Keyy »
https://forums.nicoclub.com/240-keyy-u3357.html
Thu Jul 15, 2004 6:33 pm
input shaft bearing, mine did the same stuff a while back, then it decided to take a crap while I was drifting. It will eventually get worse and worse and get to the point where the car will try to move when you have the clutch in and it is in gear, and it will get STUPID loud. Then it will blow up...
If you want a cheap fix, go to a junkyard and pick up a KA transmission, then swap the bellhousings and then put it back in. The gears are a little shorter, so it makes your car a bit slower on the top end, but you gain crazy amounts of low end sprinting ability...
