transmission noise!!! need help!!!
OJ
Car: 89 240sx
so i recently bout a 91 coupe with the problem of the clutch pedal sticking to the floor. replaced the slave cylinder and clutch master cylinder and bled the system. problem solved but clutch works like normal. only thing is when i went to start the car and let out the clutch pedal it makes a loud grinding/like someone riding a skateboard. when i push in the clutch it goes away but as soon as i let it out half way it starts to grind. any ideas?
Mod edit, no need for duplicate threads:
transmission-noise-need-help-fast-t530515.html
