ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Fri Aug 06, 2010 6:21 pm
Don't waste money on synthetics for a transmission drain every 2 years with normal oils. ATF is a good cleaner in itself, do not use Ford quality fluids. If your transmission has a drain cap on it use that then flush with an extra qt of ATF, seal up and change every 24 months, no filter, no screen cleaning, no new gasket. My QX4 is 14 years old, never a filter, screen or gasket change, but oil changed every 24 months miles mean nothing at that time interval. Now if it was the engine, I use Mobl1 synthetics every 3 months, Pumpkins every 2 years, transfer case 24 moths, Coolant 24 months, brake fluid 24 months.
