transmission lines, which goes where!!
SUB ZERO CAR FANATIC
Car: 1993 Infiniti Q45 ( SOLD)
1997 Cadillac Deville Concourse
1998 Cadillac Seville STS
2009 Infiniti QX56 LE
Q45 tech can you please give me a few minutes. i just need to know which line is the output line on transmission, the one on drivers side or passenger side??, and when it splits into 2 rubber lines at radiator end where do they both go? top rght. and top left?? please help. thanks, SUBZEROCARFANATIC
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Are you adding an external cooler?
Denver90Q
Car: 1990 Q45 145K miles beige, 1995 Q45t green 80K miles , 1998 Frontier 140K miles black
elwesso wrote:Are you adding an external cooler?
In anticipation of gobal warming? Maybe an external heater since he lives in Fairbanks.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Passenger side is supply and driver's side is return.
I believe the ATF flows top to bottom in the tanks, but will have to check.
Finally, some good input. Thanks alot Brian, i appreciate it very much.LMK if you remember what the flow direction is. thanks, SUBZEROCARFANATIC
goody90q45
Car: 1992 Infiniti Q45 (sold)
SUB ZERO CAR FANATIC wrote:Finally, some good input.
Chris- Have you got a copy of the FSM? The electronic version is better than nothing.
http://www.nicoclub.com/FSM/
No im not adding a external cooler,it gets -50*F here overheating isnt a problem i have to worry about , thanks wes. SUBZERO
WHERE would that be mike, in the back section of book, im not very familiar with it yet! thank for input mike. SUBZERO
Brian have you had a chance to find out for sure,much thanks for your help!SUBZERO
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Have to wait until the rain ends tomorrow hopefully and I will see if I can determine from the top.
Can't find it in the FSM. Pretty sure I am correct, but that's not good enough.
elwesso
2007 BMW M Coupe
I doubt it matters what direction it goes in the cooler.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:I doubt it matters what direction it goes in the cooler.
I agree, but if a tank leaks, perhaps it is better top to bottom for some ATF returning to transmission planetary set.
So i assume that line coming out of drivers side of transmission is output,from there it splits and goes in both left and right top ports of radiator,and then passenger side transmission line goes to bottom 2 ports on radiator. Is this assumption correct Q45 TECH or anyone who knows.any input brian! thanks!! SUBZERO
