Post by RBSilvia » https://forums.nicoclub.com/rbsilvia-u83960.html Wed Jun 25, 2008 11:59 am
Post by BoostFab » https://forums.nicoclub.com/boostfab-u11693.html Wed Jun 25, 2008 12:14 pm
if you pull the driveshaft out w/o draining the gear oil first it will pour out from the driveshaft yoke .RBSilvia wrote:so i'm prepping my transmission today to bolt it up to my engine and finally get everything mounted up in the car....and i notice that when i tip the transmission back (shifter lower than bellhousing), oil would leak out through the driveshaft hole.
I'm wondering if this is normal....i'm thinking its not.
Also, when i drained the oil there wasn't much in there, most likely due to it spilling out the back.
What needs to be replaced to fix this, and how hard is it?
Post by RBSilvia » https://forums.nicoclub.com/rbsilvia-u83960.html Wed Jun 25, 2008 5:27 pm
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
