fitch9014 »
https://forums.nicoclub.com/fitch9014-u32378.html
Sat Nov 11, 2006 5:57 am
when i removed my valve covers to paint them, one of the half plugs fell out of the back and it leaked from there. usually, but not always, if it's leaking from the valve cover, you'll see or smell motor oil burning. right now, if it's a very slow leak and you can see it from the underside of the car it sounds like a rear main. mine's doing this sort of old horror movie monster ooze from the same place and it's definately motor oil, so i'm pretty sure napa's gaskets are crap because i replaced all the gaskets when i put the motor in a year ago and it oozes all over now. hope this helps, but i wouldn't worry about it to much as long as you check your engine oil frequently. And to second, make sure it's gear oil because "There is no mistaking the onionesque-sneaker funk of 80/90"
