transmission Leak
GTR24
Car: 1995 240sx
2015 370z
My transmission started to leak after i installed an aftermarket short shifter. I could smell gear oil under the car and the transmission didnt feel as smooth.
(btw i cheated on the install by not dropping the transmission)
I thought the leak was coming from the shifter seal, so I installed a new seal along with the stock shifter assembly. I changed the gear oil, thinking this would solve the problem, but NO. Its still leaking with the more symptoms. Now its grinds when i shift into 3rd.
I suspect the seal to be out of position, or the 6 bolts on the shifter are not evenly torqued, or its leaking from a different source.
All the help would be appreciated, thanks.
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
You need to pin point where it is actually leaking from. Also you don't have to drop the transmission to install and shifter. A grind is typically a sign of syncro wear.
bruinbear714
GTR24 wrote:My transmission started to leak after i installed an aftermarket short shifter. I could smell gear oil under the car and the transmission didnt feel as smooth.
Clean up the area really well and see where the leak is coming from.
Did you replace the boots during install?
Also the manual transmission is quite picky on the fluid.
presidential
Car: 1992 240sx hatch, 1993 240sx coupe
They commonly leak from the drain plug (debris in threads). Mine does leave a few spots on the ground, I just top it off every oil change.
GTR24
Car: 1995 240sx
2015 370z
i noticed my drain plug was glazed with oil after the transmission oil change. Can't i just clean out the threads of the drain plug?
Amtk240
Car: 1997 Nissan 240sx SE Red S14, and 1995 Nissan Navan 240sx Ruby Pearl S14.
I have actual smoke coming up through the shift boot! It has been happening for the past three weeks and I can smell a faint smell from the smoke. The smoke is hard to see and the longer I run the car, the more smell I get. I guess it is time to fill my transmission up.
nifares240
Car: 1993 240sx Black-Project Car, 1993 240sx Red-SOLD, 1994 Sentra, 2004 Nissan Sentra SE-R SPEC V-Daily, 1999 Toyota Camry
your leak is coming from the shifter. the smoke is from the oil dripping on the exhaust pipe. did you use silicone RTV seal?
GTR24
Car: 1995 240sx
2015 370z
I used High-Temp RTV silicon on the shifter. I tightened the 6 12mm bolts as best as i could. 4 of them from the top and the 2 front ones from beneath the car. I think my gasket shifted out of place.
But the gear oil isnt dripping or leaving puddles, its just smeared on the bottom of the transmission and drive shaft coupler.
