IceCold240 »
https://forums.nicoclub.com/icecold240-u13885.html
Mon Feb 23, 2004 10:58 pm
I've had some shifting issues as well since my slave cylinder and clutch was recently replaced. The first issue for you to make sure is that the hydraulic clutch system is working correctly, and as candela says, if it is, then the issue is inside the transmission.
You can adjust the clutch via the master cylinder pushrod. Look underneath your dash, follow the clutch pedal up to the U shaped clevis pin, and the bolt from the firewall that threads into the U is the master cylinder pushrod. If you go to 240sx.org, underneath their faq there is clutch service pics. It'll show you what it looks like.
Also make sure the system is bled correctly. Those pics also show you how to do that.
One thing to try real quick, can you shift when your clutch pedal isn't all the way to the floor, but partially engaged?
