GBSilviaS15 »
https://forums.nicoclub.com/gbsilvias15-u18015.html
Wed Jul 06, 2005 10:21 pm
What a coincidence I had the same exact problem - it took me 4 hours.
Take a deep breath.
When I finally got the bellhousing within inches of the block, I went all the way to the back of the transmission (towards the driveshaft), assuming the driveshaft is out. I got myself in a position where I can kick the whole bell housing in towards the engine block. Kept kicking and kicking and kicing and kicking, and finally tried to put any bellhousing bolts in that would reach, and started screwing them slowly, and eventually got them all in.
Okay, I suck at explaining I guess.
Pretty much what you do is support your bellhousing with a hydraulic jack with wheels. Then go to the back and kick the bellhousing until it gets close enough to bolt the bellhousing bolts on. Then start bolting the bolts on and eventually the bolts will force the transmission in there, that's it.
