Keachj06https://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113transmission issue?? small hole plus slave pics inside.Sun Dec 09, 2007 1:30 pm
Postby
Keachj06 »
https://forums.nicoclub.com/keachj06-u82400.htmlSun Dec 09, 2007 1:30 pm
is this all normal there was a lot of black gunk on the transmission case and the slave cylinder boot had a lil fluid too but it was a lil thinner and clearer.
is that lil hole normal or should i patch it using something like jbweld. lol iam new to these cars so go easy on me.
Postby
nightkid86 »
https://forums.nicoclub.com/nightkid86-u34996.htmlSun Dec 09, 2007 1:34 pm
That little hole lets moisture or clutch material exit the clutch housing. It is a good thing to have. If there was oil coming from the hole that may mean a bad rear main seal.
Postby
Keachj06 »
https://forums.nicoclub.com/keachj06-u82400.htmlSun Dec 09, 2007 1:37 pm
ok feel a little better but heres the other issue the clutch is slippign really bad and b4 it started slipping the clutch pedal would sometimes stick to the floor board i bled the master and the previous owner replaced it but did not replace the slave could that be the issue?
