transmission is sticking? Help!
300freekzx
Car: 1990 300zx N/A, 1992 Honda Accord LX , 1991 Honda Accord LX, 2006 M35 Sport
I have a 1990 300zx I just bought. However the guy who sold to me did not tell everything. The transmission shifts well at night when it is cool out but when it is hot it seems to not want to go into gear after driving for a while. I actually had to force into 1st gear when I was tring to pull off. I think it might be the pressure plate. What do you think?
240six
Check the fluid level and bleed the system.
300freekzx
Thanks will try that
Milo (San Antonio)
Car: Project LOWFATZ (weight reduced slicktop TT)
Agree, check the fluid level. I am assuming it's a 5spd...correct?
Just curious, does it feel like the clutch is slipping?
300freekzx
yes it does. I need to check it. I will do so in the morning. By the way nice car!
onelessissue
Car: 90 300zxtt
hey man every time they come into the shop with that problem we drain a quart of gear lube out and put a quart of ATF in ti fixs it every time if you change the trans oil and put to thick of oil in it it will also do that
freakonaleash1187
Car: '93 300ZX N/A, '97 200SX SE
Try changing the transmission fluid, I would suggest putting Redline MT-90 in the transmission, as would most of the Z world.
300freekzx
thanks guyz.
