transmission help
TT2+2
Car: 1990 300zx 2+2 TT(almost widebody)
this is kind of a tough one. i had the tt swap done about 3 months ago and along with it i replaced the clutch and flywheel. i'm almost positive my sync ring for fourth gear is shot, and think the one for first is starting to. when i go to put it in first it's fine if i do it slowly and just wait for it to slide in, but if i push it in it klunks like hell. but anyway, i'm asking for an opinion on rebuilding my current transmission or wether purchasing a new one is the better way to go. or a more inexpensive fix if anyone has any sugestions
flfuzzz
Car: 91 Nissan 300ZX 2+2
Try replacing the shifter bushing. It could be part of the problem. Also try using Redline trans fluid. If that doesn't work, then go to the more expensive repairs.
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
2nd the Redline fluid. Its MT90.
TT2+2
i replaced the shifter bushings when i did the swap so i'll try the redline fluid and get back to you thanks guys
TT2+2
tried the redline fluid and it unfortunately didn't worki'm looking into the re-designed trannys for the 97+ jspec moddles and was wondering if anyone had any insight on them
DustinZ
Car: 1990 Z32, rb25 s13, 1980 S130 10th anniversary, 1978 5speed fact ac s30, s2 rb26 on deck!
Did you check and or change your pilot bearing? Alot of people don't replace it and it will cause the input shaft to drag even when the clutch is released and cause premature wear on your synchros.
