transmission having trouble with 2-3 shift (1994 Q45)
guadofreak
Car: 1994 Q45t
Whenever I am at wide open throttle (WOT) the transmission shifts perfect from 1-2 but when 2-3 comes around it seems like it bangs against the rev limiter or teeters between 2-3.
Is that an indication of rebuild time? it only happens at that 90-95mph mark. If I let it out it shifts and then i can stab it again and it's fine.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
How about a brief transmisssion service history? When did you install a cooler? What does "let it out" mean?
guadofreak
Car: 1994 Q45t
no transmission cooler yet. 153K miles. Car was driven mildly until now..lol
Let out meaning letting off the gas.
transmission fluid had been flushed every 30K (the proper way)
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Well, I am certainly not a transmission tech, but if the fluids didn't show significant age by discoloration, it shouldn't have the shifting problem. Did you change the filter (screen) and clean the pan every other time?
Q45tech will probably chime in. I would suspect a varnished valve or bad solenoid, but that would only be a guess.
Q45tech
Without measuring the exact {BG machine} exchange time [3.5 minutes] hard to GUESS at the amount of pump [bypass internal] leakage.
Try using Mobil 1 Syn ATF with a dash [half bottle 5-6 ounces] of Lubeguard Red [not Black] no friction modifiers. It will shift faster before rev limiter.
150k [10-11 years] is very decent transmission life, gotta expect some old age symptoms by then.
