Quick240 »
https://forums.nicoclub.com/quick240-u2949.html
Thu Aug 14, 2003 7:24 pm
From the pic in your other thread. 1) is Neutral Position Switch, 2) is VSS, and 3) is Reverse switch.Just replace with the sensors from your KA that are in the same locations. If I remember correctly the KA has an extra sensor or two, so you just leave those alone. Also you can test #1 and #3 by seeing if they have continuity when they're in the correct location. #1 should have continuity only when in neutral, #3 should have continuity only when in reverse.
