transmission harness????????????help
sgpnismo
Ok, i found a plug directly under my fuesbox last week and there is not a plug on the transmission harness or main harness to plug into it, the ka transmission harness does have the plug for it but the sr one does not. Is there supposed to be something plugged into this? Should I be using the ka transmission harness instead of the sr transmission harness? The plug is underneath the fues box by the battery area. Thanks a lot.
ride4lame
i don't know what plug you are talking about... a pic might help...but you should use the ka transmission harness and sensors. They work with teh sr transmission.goodluck
quiksilvia
Car: 95 s14 se
not all plugs will be used either
sgpnismo
so the ka transmission harness will plug onto the sr's starter, alternator and oil pressure sending unit?
sgpnismo
i dont have a digital camera so sorry for no pics, but the plug is attached to the bracket that holds the fusebox in the engine bay it is directly underneath the fuse box, it is a s13 also. There are 2 or 3 plugs on the engine side of the fuesbox and 1 right underneath it you have to actually move the fuse box to be able to see it.
Bryson
Car: 93 240sx Hatchback /w Sr20
I know which one your talking about, there is nothing giong into it on mine either.. BUT HEY WOULDN'T YOU GUESS IT?? MY ****NIG SR STILL WON'T START AFTER 3 IGNITORS and 2 CAS sensors!!! AND THE ECU IS KNOWN TO BE GOOD!!!
sgpnismo
lol, maybe where having the same problem! Cause im getting spark and fuel, only other thing i can think of is timing is way off or my battery area wiring is wrong. So are we going with I should be using the ka transmission harness and it will plug right in to the sr?
robbbby
I had something plugged into mine. Not sure if it was off the transmission harness or the main.
sgpnismo
well if you use the ka transmission harness there is a plug on it thats for that plug under the fuse box, im just asking if you can use the ka transmission harness on the sr?
