naha_music »
https://forums.nicoclub.com/naha-music-u23638.html
Fri May 05, 2006 9:11 am
ok, i finally got the transmission off now. it was being held on by one bolt that was overlooked, hiding behind the rear trans/motor mount bracket. once i got that unbolted, the transmission slid off with no probs. i've decided to replace the clutch while i had it off so i'll be sure to do a write up for skeluhtor. i've already got a new clutch kit at kragen's for $116.
anyways, i got a small problem.... i'm replacing the transmission in a b13 ga16de. the transmission that i ordered from venus i believe is out of a b14 (it has b14 stamped on the transmission). everything is identical as the b13 except the o/d of the center spline is ever so slightly smaller that the original transmission, thus making the throwout bearings alittle loose. i went to the autoparts store to check if they're different sizes of the b13 & b14, but they said they use the same sizes for both. does anyone know if the throw out bearing will be okay with it being alittle loose?
