Would you have a link to that kit? I've looked for it but can only find the US specAce2cool wrote:Synchros. It's a known issue that they finally fixed with the '99 spec trans. You can replace the synchros with a kit.
do you mean my jdm trans wont use the same synchros, or the '99 spec wont trans wont fit on my 90 tt?Ace2cool wrote:The US spec is the one you need. They don't really make the JDM kits, because they don't fail. They don't swap either, TMK.
Your transmission is the same as a US trans. In 98, when nissan made a few changes to the 300z, one was they upgraded the transmission. It'll bolt up to our engine, the thing that is different is stronger synchronizers.Shoey2 wrote: do you mean my jdm trans wont use the same synchros, or the '99 spec wont trans wont fit on my 90 tt?
ok good, thats what i was hoping. im gonna make sure that $1700 quote i got at work is still the same for the later model trans.zcar93na wrote:Your transmission is the same as a US trans. In 98, when nissan made a few changes to the 300z, one was they upgraded the transmission. It'll bolt up to our engine, the thing that is different is stronger synchronizers.Shoey2 wrote: do you mean my jdm trans wont use the same synchros, or the '99 spec wont trans wont fit on my 90 tt?
Thats problem... i dont have any of those two. And if i did, lowering the transmission on these cars is such a PITA!ThisIsSparTTa wrote:I don't know if it adds a ton of value to the thread, but my transmission, which theoritically has 165k on it, grinds on hard shifts from 3rd to 4th when really going at it. I've tried a little rev matching or double clutching, but haven't had much luck...also, I'm not running it that hard very often either. Anyways, the synopsis seems to be that (as expected) the synchros on these guys go out over time, but at least it doesn't seem to be a common problem on any 1 gear. I haven't looked as much at the Z transmission, but when I was looking at RX-7s which have 1 that always fails, it was described as not too bad to replace the synchros...if you had a transmission lift, and a gear puller.
Problem is that the bolts connecting the exhaust are welded from all the rust and corrosion ( not to mention the heat from the exhaust ) and if i cant get the bolts out i have no other than to cut the exhaust and weld it back in once im done. Whats the easiest way to remove the upper transmission bolts? I already deleted the EGR so i have a bit more room to work in.Shoey2 wrote:i agree with ace. pulling the trans on these cars in a easy as pie i dont see what all the fuss is about. exhaust, driveshaft, bell housing bolts, trans mount out, pull and done. just get long extentions with a swivel. comes out with hand tools.
