mbmbmb23 »
https://forums.nicoclub.com/mbmbmb23-u19119.html
Mon May 25, 2009 4:46 pm
Your clutch master cylinder or slave cylinder is probably leaking and leaving you with minimal hydraulic pressure in your lines....thus sluggishly engaging/disengaging. If the slave is leaking you can see it if you get down there and have a friend pump the clutch......but the master cylinder is harder to see since it can leak inside the cabin....and leak fluid down into the sound deadening behind your pedals. Your throw out bearing might be making noise because its not fully disengaging.....or because its toast. Good luck....keep us updated.
