carlos_knology »
https://forums.nicoclub.com/carlos-knology-u278.html
Fri Jan 24, 2003 2:26 pm
Thanks for all the replies.
I used a pump to pump out the excess fluid (out of the dipstick tube) using a long thin hose. The transmission was overfilled by about 1 quart.
And while messing with ATF fluid, decided to replace the power steering fluid using the turkey-baster method. Emptied the reservoir, refilled, started engine, turned steering wheel for about a minute or two, shut engine off. Redo. Did that about 4 times before the fluid didn't have that nasty burnt smell to it.
Carlos
