transmission fluid
midnightclubbaa
Car: Cars Clothes Music Girls
how do i drain my transmission fluid? is there some sort of plug or something?
midnightclubbaa
oh almost forfot it's on a 91 240sx with a KA24DE
navysnail
drain plug in the bottom, use a 1/2 inch drive ratchet to drain.
fiznat wrote up a how-to on this a while ago, ill go find it
edit: assuming your talking about manual transmision
MikeYeeS13
Im pretty sure the only way to fill it is through the dipstick "tube"correct me if Im wrongI always thought there could be a better way, especiallly with the thick weight of transmission fluid like 80 90
ZULU
fill by the dipstick ? Umm my transmission has no dipstick the fill plug is under the car on the left side of the transmission.
thelinja
He's talking about an AT.
navysnail
if the at has a drain plug it will be on the pan. if there is no drain plug, then you just have to pull off the pan to drain it.
