transmission fluid
echelonphoto
Car: 2006 G35
Shifting on my 6 speed is a little notchy...any lube I can use that works wonders?
telcoman
echelonphoto wrote:Shifting on my 6 speed is a little notchy...any lube I can use that works wonders?
Perhaps a hot 25 yr old to shift for you?
Telcoman
Poyzinous
Car: 2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
um, BG products has a tube of special stuff, part number 325, its manual trans additive, it might help. If its not the transmission, the clutch alignment may be off or the pedal not set properly, causing a bit of a stick and unnecessary friction when shifting. Thats rarely the case though, as the clutch install is super easy and hard to screw up( for a tech)
