I am sure some of you guys have seen the post on 502 about my transmission problem. Here is what is goin on anyways, from 2nd to 3rd the gears do not engauge for a second or two longer than they should at around 3 to 4 thousand rpm. I have just replaced the fluid from whatever it was to redline racing ATF which i am sure is probly the worst pick of fluid for that transmission.
Question is, should i go to get my transmission fluids replaced ASAP (today) or should i hold if off for a day or two untill me and my buddy can replace it??
