transmission Fluid
RichardG35
Car: 2003 G35
Automatic G35 transmission fluid cap needed.Drained the g35's transmission (part of my PM) but can not find the listed amount it takes. And with the fluid being so clean it is hard to read.
Any one done this yet?Thanks
Never mind, just found it thru several link on this forum. Man this place is awesome.
Here is what I found.
The amount of new transmission fluid to use should be 30 to 50% of the stipulated amount.ATF: Genuine Nissan Matic J ATFFluid capacity: 10.3 (10-7/8 US qt, 9-1/8 lmp qt)
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The best way to do it is to measure the amount that you took out and replace it.. Out of that 10 quarts total, youd be lucky to get out 4 quarts out of the pan. the other 6 quarts is inside the valve body, torque converter, and so forth.
Road Ruler
Car: G35 sedan prem
I read some where that the Infinity transmission fluid is about $12. a Quart. Is this true. I know this fluid is "special". Is any aftermarket lube company making a product that is approved for use in the G?
Q45tech
When JATCO designed the new transmission it assummed a bigger role in warranty, thus they created a special formulation ATF and required its use in their transmission before they would honor warranty pass thru from Nissan.
http://www.jatco.co.jp/ENGLISH....html
Besides being a decent hydrolized synthetic it has special additives to control different slip stick ratio of the new dual lockup clutch. Until the new 5AT Nissan AT all had single lockup clutch!AT your own risk you might try adding Lubeguard BLACK in varying ratios [start with half 5-6 ounces in 10 quarts of Mobil 1 Syn ATF.
All you have at risk is transmission failure.......the color will give you away if warranty is a concern!
Remember dealers markup parts cost by 100%.
szh
Car: 2018 Tesla Model 3.
By the way, the J Fluid cost has come down recently (competition perhaps from other sources).
At the 30k mile point, I had a transmission flush done on my M45 (also did it at 10k miles) and it was no longer as expensive.
Z
C-Kwik
Does the car not have a dipstick to check the auto transmission fluid level? Unless they changed how we are supposed to check fluid level since I last played with an autotranny.
Road Ruler
Car: G35 sedan prem
I removed the cap off the top of the transmission filler pipe. There is no dip stick!! What a pain! I believe some G's have dip sticks?? Can I buy a dipstick for a 2003 G from the dealer??
Thnxs guys, appreciate any info you can forward.
