transmission fluid
C - ROD
Car: SR20DET pignose hatch
i was reading somewhere else on here & someone said that synthetic gear lubes are not susposed to be used in the sr transmission because of the brass synchros
the reason i ask is cuz when i did my swap i uses valvoline 80 - 90 full synthetic in my transmission & it grinds the 2nd, 3rd, & 4th gear synchros
anyone else heard of this happening cuz of the synthetic 80 - 90
180fan
Car: 89 fastback
GL 4 in the transmission, not GL 5. Don't matter if they're synthetic or not as long as you get the GL spec right.
C - ROD
well could the GL - 5 make it grind
Fenvy
Car: 2005 350Z Base 6MT
no, but the gl5 will eat your brass syncro, wa ha ha
teddy
Car: Saab Turbo and MR2
yep, only GL-4 in the transmission, but you can run GL-5 in the stock open differential.
D1 guy
Car: 1997 kouki S14 SR powered w/400whp and a stock 1994 FD R2 (26,000miles),
not trying to jack your thread or anything, but Ive been having the same problem except Im running gl4. I just got finished with the swap about 2 weeks ago and for some reason, it grinds 2nd and 5th sometimes. Its rare though. Do you guys think that maybe since our trannys have been dry for awhile that itll clear up or is it serious? BTW I have a b&m short throw....could that have anything to do with it?
Neil
Car: shooting laser guns
short throws MAY over time increase synchro wear if youre a d!ck to your transmission and try to shift super fast. If youre gentle but just enjoy the click into gear feel, the short shifter shouldnt present a problem. Id use Redline MT-90, its the right weight and only GL4. my KA transmission was real notchy and ground 2nd and 3rd religiously, but its smoother now after like 4000 miles. Not saying it FIXED the transmission but, it is what it is
