transmission fluid check
cheapazz
Car: '05 G35 5A/T coupe
I looked in the owners manual and it just says "take it to the dealer". I do have a dipstick in the tube, I just need to know if I check it like a normal trans.....warm, in park, on level ground etc. or if there is something special to it. I know some vehicles require being in N or even some in D. thanks for any insight to my dilema.
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
I have always checked mine while warm, running, in neutral, on level ground, after putting it through P, R, N, D, then back to N, and check.
My fluid looked like coffee. I had it changed today, as well as the diff fluid.
cheapazz
AAHHHH, I will try THAT! When I checked it in P, it was too full. Thanks for the input! AGAIN
rmezz13
Car: Had 2004.5 Nissan 350z
Have 96 f250 and mommas 07 Murano
as far as warmed up, from a cold start you should go drive it for about 15 minutes before checking it. Make sure the transmission is up to temperature before checking it....... Just a tip for those who don't know....
cheapazz
So I went to the local Nissan dealer and asked them........warm, @idle, in park. I think I'm too full. Does $165. sound right for the transmission flush?, everything included.
lomita
Car: 05 G35 Sport Coupe
Sounds reasonable. Oil at $8/qt. x 10 quarts plus labor.
We only dump the pan ATF each 7500 miles and change out 3.5 qts. We never do a full flush. It's cheaper and does the job.
Our trannys have never given us problems since we began implementing this procedure on all our vehicles with A/Ts.
av8or
Car: '07 FX35 AWD ... '06 4runner limited ..... A320 F.O. (my other ride)
cheapazz wrote:So I went to the local Nissan dealer and asked them........warm, @idle, in park. I think I'm too full. Does $165. sound right for the transmission flush?, everything included.
nissan charged me $140 for a transmission fluid exchange not a flush... make sure that it is a flush not just an exchange.... price difference is suspicious, considering you would need more than 10 quarts for a flush as against 4 quartz for an exchange...
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
My local nissan dealer did a flush on my daughter's 00 Max for $139 a month ago. They also did a radiator flush for $109.
turbobrian
Car: 07 G35x
I have a 07 with 30k. Would you say it time for a full flush for me?
Beancooker
Suppose to flush it every 30k. I highly suggest it. Nissan charged me $139. for a flush. It uses a total of 14 quarts to flush, and the transmission and torque convertor holds 10.5 quarts. They do waste 3.5 qt while flushing, but Adrain told me that is to make sure that all the old has been flushed out.
cheapazz
At almost 25,xxx so time to start a list..............oil change (castrol syntec) .......checktranny flush at dealer.........checkanything else I should do while I'm spending the time and money?OH YEA.......almost forgot, change and flush the brake fluid.....once a year Very important!What else..what else.........I'm on a roll..........
Beancooker
Flush coolant
Change in cabin air filter
Wiper blades
The list goes on...
