transmission fluid change
M45xATL
Car: 2008 M35 Sport
I'm having the transmission fluid changed (low pressure flush) on my 2008 M45x and need to know if the fluid for the awd system needs to be changed as well?
dlibson
Car: 2006 M35X
You should. It's very easy to have done at the same time. Just did it today on mine.
lovemycarM35
Car: 2014 Lexus GS 350
With F-Sport Package
Nebula Gray
19" wheels
12.3 inch display
Navigation
Ok so how many miles should you go between changes I got mine done at the dealer around 65 I'm 74 now
szh
Car: 2018 Tesla Model 3.
I do my transmission flush (powered system - not just a drain and fill) every 30k miles.
Z
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
szh wrote:I do my transmission flush (powered system - not just a drain and fill) every 30k miles.
Z
Probably a good rule to live by. The first one you could probably go to 60k or so, but 30k after that is a pretty good interval (every 1-2 years for most people)
MOWellsinVA
Car: 2007 Infiniti M45 Sport (Obsidian Black w/ Graphite interior)
I had my trans power-flushed by the dealer at 64,000 miles. Took the car in for the recall fix and it was recommended that since my car was at 93,400 miles that another trans flush and differential fluid change was recommended. I'll plan on trans flushes every 30,0000 miles from now on.
