DeXteR »
https://forums.nicoclub.com/dexter-u32945.html
Fri Dec 28, 2007 9:18 am
For auto you need to drop the pan to remove the fluid. Go around the transmission pan and break the bolts loose. Then drop one corner, starting in the corner and working your way down each side until it starts to come out. use a large drain pan as it's going to come out all over the place. REMEMBER when the fluid stops dripping, there's still fluid left in the pan! Be carefull pulling the pan all the way off and pour what's left into the drain pan you're using.
Make sure to replace the transmission fluid filter as well (just like doing an oil change) while you've got the pan off and the fluid out.
When it's time to refill, do it through the dipstick with a funnel.
That's just my $.02
