gwoods »
https://forums.nicoclub.com/gwoods-u72022.html
Sat Sep 22, 2007 4:16 pm
I'd do a transmission fluid change every 30k change the differential fluid at the same time.
On my Hemi ram the transmission had 2 filters. They were $50 plus it held 16 quarts of fluid at $4.50 a quart for MOPAR ATF+4. YIKES!
I changed the fluid every 25-30 k miles and still lost the transmission at 57k miles while beating a Celica GTS on I-10 :-) Pictures of rebuild below,
I went through 3 differential rebuilds in the same amount of time although one was completely my fault ( doing doughnuts with the rear tires lit up :-) wheel hop CRUSHED the pinion bearing I had to pound it off with a air hammer LOL)
