Post by coolyun_98 » https://forums.nicoclub.com/coolyun-98-u59252.html Mon Mar 17, 2008 9:28 am
Post by gr8scott72 » https://forums.nicoclub.com/gr8scott72-u37410.html Mon Mar 17, 2008 10:02 am
iirc, it's closer to 4. Just buy 5 and you will have at least one spare.coolyun_98 wrote:I know our Js hold 8.3litter/8.75qt of ATF, but how much of it is in the oil pan? Some say 3qt and some say 4qt. I guess this information is pretty important for and I hope all the gurus can help us.
Post by misfit6794 » https://forums.nicoclub.com/misfit6794-u84489.html Mon Mar 17, 2008 10:50 am
Post by gr8scott72 » https://forums.nicoclub.com/gr8scott72-u37410.html Mon Mar 17, 2008 11:14 am
Another trick is to drain fluid in a pan and then pour it into a container that allows you to measure what you pulled out and then just pour that much back in.misfit6794 wrote:4 maybe 4 and a half. Put 4 in, get it warm, then check the fluid level again.
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
