misfit6794 wrote:Its a screen but its somewhat enclosed, so I would imagine it would be hard to get it clean, that and transmission fluid is really sticky, so im not sure what you would clean it with. If you are going to go through the effort to drop the pan, I would just put up a new filter, they are pretty cheap. Those trans cooler lines are also a pain to get out of the way to get to the bolts that hold the pan.
I didn't move the transmission lines to drop the pan. Just worked around them.
I too, put my vote in for just replacing the filter while you have it off. Don't forget to clean off the magnet in the bottom of the pan. Then Mobile 1 fluid and Lucas treatment.
