transmission drain plug s13
slideshow_S14
Car: 1995 240sx
I know this is a dumb question but i cant seem to locate the transmission plug on my s13 hatch. If anyone can help me without making fun of me i would appreciate it .
Hijacker
Car: '92 240sx Convertible
'94 F-150
Drain plug is directly on the bottom of the gearbox in front of the sandwich plate. instead of being a bolt, you insert the chuck from a 1/2" ratchet/breaker into the bolt to loosen/tighten.
The fill plug is halfway up the driver side of the trans. Just in front of the sandwich plate. It's a square protrusion and you need a 12 point 17mm or 19mm. I can't remember the size exactly, but becuse it's square, only a 12 point will go on.
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
cant you fil it through the shifter hole.
duffman1278
Car: 89 240sx Hatch, the wildcats!
You can't fill the transmission from the bottom. But yes, just like hijacker said, its literally at the BOTTOM of the transmission, you can't miss it. Not a regularo looking bolt though, its like inverse style
duffman1278
Basically looks like the black bolt on the right
