I disagree... There should NEVER be issues with trans shifting when the car is cold......!!!!! Sometimes if a problem occurs when its cold its a sign that something is coming.....maxnix wrote:Operating problems when car is not warmed to operating temperature are to be expected, expecially if OEM heat exchanger is by passed.
Cold behavior diagnosis is alsmost useless because the car is not meant to be operated that way.
Just to stay on topic.... How were the pins (male/female)in the loose connector? Could have junk or corrosion... especially if the little gasket is gone.gniknave wrote:
I did a search after reading about what Squee was talking about - Turbine Sensor... It then came to me that when I was under the car last week, there was a loose connector for "something" (didn't know what it was for) on the side of the transmission. After seeing pictures, I see that the connector was for the Turbine Sensor.
What exactly are the symtoms (not found in search) of a bad turbine sensor?
Q45tech wrote:I have the Level 10 transmission with the 1st gear start TCU...
This is the thread topic not a oem rebuild transmission or TCU..........Level 10 does things to create a racing transmission these change the normality of the cold process.
Asinine. The common expectation of a Level 10 transmission is longer life than OEM.Q45tech wrote:Did the modded transmission last 12months/12 k? What is your complaint?"
Well, that'a all well and fine, but ATF below 140° F is not at operating temperature. I am betting Nissan engineered for 176° F ATF operating temperature.elwesso wrote:I disagree... There should NEVER be issues with trans shifting when the car is cold......!!!!! Sometimes if a problem occurs when its cold its a sign that something is coming.....
You should indeed have a Corolla with that ignorant attitude.Jesda wrote:Operating problems at cold temperatures are NOT to be expected. I expect the car to shift when I start it up and put it in D, even if its freezing outside. If that much can't be expected of a $55,000 luxury car, then I'd rather have a Corolla.
Just FYI, my issues are electrical, not with the transmission, so what happens would happen with any trans that was in the car...qship96 wrote:guess I wont be looking to get a level ten transmission when mine goes,with Wes`s issues,and now this one,combined with q45techs comments,I will stick with OEM when the time comes! thanks for the insight...........
You sound like you work for a Volkswagen dealer.maxnix wrote:You should indeed have a Corolla with that ignorant attitude.Two words for you:Operating Temperature.I believe you will find it referenced in the owner's manual.
funny,, the posts I have read all are transmission related,and common thread is the level ten unit-read q45 techs posts again............oem reman is much more reliable in 99% of unmolested q`selwesso wrote:
My level 10, Robs level 10, and Evan's level 10 transmissions have all acted normally, except with these electrical issues.....
People sure like to put a bad name on things when they dont really know whats causing them......!
"...well controlled shifts that maximize driveability and minimize heat build-up and wear in the transmission and wear-and-tear on the vehicle."Q45tech wrote:Common expectation of longer life?
So is it the 2-3 shift thats starting to get iffy? how and when is it making noise?sijoko wrote:I have about 110k on the Level Ten. I drive my car hard and it has held up pretty good. It is starting to get noisey now and the 2-3 shift sometimes acts up. This seems to be a common problem with the RE4R03A.
I am curious if IPT (Import Performance Transmissions) can do a better job.
I am waiting for the new GM 6L80E to start showing up on eBay. That trans would be perfect for the Q.
It would not surprise me that you have not had to replace an OEM reman transmission with a cooler in the past 7 years.....if the person drives 20K per year then that is 140K of which probably a lot is highway mileage which should be easier on the transmission than city driving. If you consider out of the last 7 years the 6th year and then count through last year to 2005 then the mileage on the replaced OEM reman units is much much less than the 140K on these redo trannys unless you have a crap load of people doing nothing but driving all day long for a living and keep returning to T3. Not to mention the numbers of cars that probaby get sold off to some owner who does not know what to do with the car, people who move away, or an accident and car is totalled out.Q45tech wrote:To my knowledge we have never replaced a oem reman we have installed in the past 7 years [with an auxillary heat exchanger].
I am and I operate them correctly.Jesda wrote:I thought you were meticulous about your cars?
