transmission differences?
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
Sorry if this has been covered. I am just wondering what differences(if any) there are between r33 rb25 transmission and the r34 neo transmission. Thanks for your time.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
R33 = push type clutch setupR34 = pull type clutch setup
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
So would a neo trans be useable on a r33 motor?
Coolwhip
Vendor
with a pull type clutch (read: change your clutch)
the use of a pull type slave cylinder.
And you're set.
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
Alright thanks for the info. Hopefully I can find a r33 trans, or I will have to buy a new clutch again lol.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
the lower shifter bushing is the small one on the r34 and the r33 is the larger lower bushing, also the r34 shifter has a bend in it as well ,push n pull diff as well
gawdzilla
Car: none
you can convert an r34 trans into a push type. search on here there are a few posts about it. i've done it before along with a few other ppl
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
Thanks for the info guys. I think I may try converting. Im going to search it now.
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
gawdzilla wrote:you can convert an r34 trans into a push type. search on here there are a few posts about it. i've done it before along with a few other ppl
So I searched and the best I came up with was someone else in the same situation, but he also had no responses that were useful. Do you think maybe you could shed some light on it since you have done it?
Coolwhip
Vendor
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
Coolwhip wrote:zerothread/283159
Your the man, I was just looking at your build thread to. Keep up the awesome work!
Coolwhip
Vendor
thx
placham
Car: 1992 Geo Prizm (4AFE)---Gone
1990 Nissan 240sx Coupe (RB20DET powered),
1994 Toyota Celica GT (3SGTE swapped), 1995 Nissan 240sx KA24DE,
2011 Nissan Sentra SER Spec-V
Also isn't pull type clutch more expensive than push type to replace.
Coolwhip
Vendor
placham wrote:Also isn't pull type clutch more expensive than push type to replace.
In many cases, yes.
REDLN
Car: 95 Nissan 240SX SE
can you swap out the shifter arms? where the shifter ball goes. also how do you remove the shifter arm so you can get the rear housing off? i see it has a pin in it but i don't know if i can punch it out the other side. sorry if i tread jacked.
