my rebuild was much less and that was w/ a shift kit/ shop around should be able to trim $500 off pricelattero65 wrote:$1900.00 for a rebuild at local shop. Food for thought.
Not unless you want food poisoning!lattero65 wrote:$1900.00 for a rebuild at local shop. Food for thought.
lattero65 wrote:$2351.00 But it's up and running great.
Amen, and might ask them how many Q45 transmissions they rebuild every month. That is where the crux lies. Nissan bench is set-up specifically for each model rebuild. Tolerances are as-new tight.Q45CALIBER wrote:DAMMMNNNNNN!!!!!!!!!!
Just a tad bit high.
The 1991 that i pulled my transmission out of has a little heat exchanger next to the transmission pan, then it went to a cooler in the bumper, then to a filter that looked like an oil filter, then back to the transmission..elwesso wrote:94-96 Trans religiously last longer due to the dual heat exchanger and filter right from the factory!
its not the same setup as the stock 94, with the twin RADIATOR coolers.defrag010 wrote:The 1991 that i pulled my transmission out of has a little heat exchanger next to the transmission pan, then it went to a cooler in the bumper, then to a filter that looked like an oil filter, then back to the transmission..
since mine had the dual coolers and filter from the factory, should that ease my fears a little bit?
No not really, it would have to depend on maintenance..... However, i wouldnt think it would go for another 30k without some sort of attention.defrag010 wrote:you didn't say radiator, you said heat exchanger.. which can be alot of things
So either way, the concensus is that the transmission will die soon no matter what?
