transmission crossmember not lining up on sr20de swap
gundamx_105
Car: silvia
i have an sr20de silvia Q's engine/trans in a hatch s13 93' 240sx.
i dropped it in without messing with the motor mounts, i left the originals in there as they would not come off the chassy(rusted on). the motor fits on the mounts good, but maybe if i adjust them it will fix my problem?
the problem is i can get the transmission crossmember on but i have to force it:( the holes don't match up perfect. they set back further. i had to force it enough to think the the mount is in too much of a bind. so now i have the crossmember back off the car and Iam thinking about drilling it.....
this is my first swap. is the crossmember supposed to be like that? does the det matchup?? should i drill the holes longer???
i left the original ka mounts in the car in the same position, would this cause problems????
Hijacker
Car: '92 240sx Convertible
'94 F-150
see if you can lossen the engine mounts a bit and it should allow you to shift the engine around enough. To get those bolts loose, go get some PB blaster or Liquid Wrench and spray the crap out of it. It should hopefully dissolve enough of the rust to get them broken
180fan
Car: 89 fastback
Are you using an AT cross member or an MT cross member?
gundamx_105
Car: silvia
ok i know what i did. i left the old motor mounts on the car in the same position and did not inspect them very well.
duh i am dumb for being lazy
one of the mounts is broke ta hell. the engine and trans is crooked.
now i have to change mounts to the good ones that came with the engine.:(
if i can get the damn bottom nuts of these mounts
ca18det_boy
gotta torch?
gundamx_105
Car: silvia
passanger side mount was ok. since both mounts were impossible to get off i left it. the driverside mount, where the rod broke through was broke, i replaced it. i had no torch so i had to saw the top of the mount off with a sawzaw and take the head off the rivit of with a grinder.:pface
now the crossmember lines up and the engine is in there good:D
