Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Wed Feb 25, 2004 4:37 am
Here's how I mounted mine... for orientation purposes, this would be like looking at the radiator from the front of the car when the radiator is mounted. Another hint - I found some nice plastic caps that fit on the old cooler input and output on the radiator at Home Depot for about 50 cents. Makes for a really clean and nice install.
I checked with B&M and they said it's fine to mount it upside down. I cut holes through the bottom lip on the radiator and then resealed it with rubber sealant (for windshields, etc). The hoses are a straight shot to the metal tubes that feed the existing cooler lines, so you don't have to splice anything together this way. I cable tied the hoses to the support member that also holds the tension rod in, so they're tucked away nicely. I like this location because it's directly in front of the auxilary fan - so it should get better air flow at idle when it really counts.
Heath
