guyaverage »
https://forums.nicoclub.com/guyaverage-u13673.html
Wed Aug 31, 2005 2:00 pm
I use one off a mid-90's Ford Explorer. They are a perfect size and do a great job. Got it out of a junkyard for $10. Make sure you splice into the return oil line coming out of the radiator.
I fabbed the bottom bracket from some aluminum angle from Home Depot. The top of the cooler has a flange on it from the factory, if you bend it 90 degrees it will bolt right to the bottom of the radiator support cross-member. Since I tool this picture I re-routed the lines from up and over the radiator to around the side through the gap on the left of the picture, about half way down (just under the headlight motor).
