1993 J30t, 71K
Removed drive shaft and when I touched the rear output shaft of the transmission I am able to get ~.06+ movement in all directions
Is this normal for this transmission?
Does anyone know where I can get the bolts for the rear drive shaft to diff hookup? They seem to be 10mm x 30mm long. The nuts are severely screwed due to the shaft being replaced by someone else and they did not have the correct tools. Going the dealer route but they will take at least a week. The grade is #11 according to the manual
The nuts that hold the center bearing to the body seem to be cinch nuts. I am assuming that these nuts can be reused with alittle loc tite on them or should i just replace?
Thanks for the help
