tranmission or clutch problem?? help~~
TS240sx
when ever i am in first second or third gear, if i drive to over 3000 RPM and when i step on the clutch, sometimes when i pull out the shift lever, it makes this rubbing noise, i dont know where it comes from, something sound like you have two sand paper rubbing against each other, what do you guys think the problem might be?
