Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Fri Sep 13, 2002 3:24 pm
You look at the mount on a lift if there is not 1/2" or more of head space [air] between the rubber and the the metal top of the mount, the weight of the car [on the ground] will allow the metal to contact and squish the rubber flat allowing drive train vibrations to transmit to the body.
It is all a system: motor mounts, sway bar mounts, shock mounts, transmission mounts, rear subframe mounts, drive shaft center bushing [doughnut]. a failure of any will result in vibration.
The failure mode is salt, heat and ozone changing the strength of the rubber to support [hang] and isolate the transmission.
In Atlanta they seem to last 90-140k I just replaced mine for the second time after 118k on the second one.The upper links last 30k, the tension rods 60k, the suspension arm rubber bushings 120k, the motor mounts, transmission mounts, diff mounts have a similar life.....the rear subframe mounts can last 240k or fail at 4k if a rear end [or severe rear fender] collision occurs usually somewhere in between...
...many don't fail at the body shop but a year later so they never get repaired!
We have more than a dozen [90-95] Q with failed rear subframe and no matter what you do to the other things a certain amount of extra vibration is always there but they won't spend the $1100 to correct it!
