Update:
I went to work one day and parked at a sort of slopped down parking spot, after an hour I grabbed an item out of the vehicle and noticed a oil accumulation about 4 inches in diameter that was not there when i parked, I got under the vehicle and noticed that in between the oil pan and bell housing that there was indeed a bad leak. I immediately checked my oil again (was weekly) and It was low, so I added some cheap oil and bought some 10w30 Quakerstate Defy. Changed it that evening (third time in 1,000 miles)
and added some Bars Stop Leak and Marvel's Mystery oil. The knock/tick subsided but came back about 4 days later. I had a well known mechanic here in town come by and check it out, his diagnosis was bad lifter(s) and not a rod... Good news in light of thinking of having to motor swap or overhaul...
If I'm not mistaken that is the rear main seal?
I'm doing research on the re-installation of the seal, seems like quite the task.
Also going to be digging into replacing all of my lifters while I'm tearing the top of the motor off...
Anyone have a how-to thread they know off top that they can link in this thread? I'd be grateful as I often have time navigating threads
Always Thanks,
Javin
