VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Wed Sep 24, 2025 3:52 pm
That's correct, the exposed terminal is ground unless somebody miswired the connector. Brown is running lights, Yellow is left turn/stop, green is right turn/stop. Using a test lamp, it should light up between Brown-White with the running lights on, Yellow-White and Green-White with the brakes applied. If that all checks out, the problem is in the trailer connection. If none of them light, that probably means White isn't making contact with the chassis.
