Trailer hitch kit?
robmcole
Car: 93 J30
Does anyone know of any companies out there that sell a trailer hitch kit? U-Haul wants $300, and I have seen a few $100 kits out there on the net, but have not found anything for the J30.
Thanks,-Rob
driverdriver
Car: NICO's longtime resident Canuck!!!
I would suggest installing a transmission cooler if your going to tow with the J30.
yodawill2000
Car: 94 Infiniti J30
Whats a good transmission cooler for the J ?Any that perform better than others ?
robmcole
Car: 93 J30
I got a question about the transmission cooler, wouldn't towing a motorcycle (300 pound trailer + 400 pound motorcycle = 700lb total) be about the same as driving with 4 guys in the car (with a capacity for 5) as of weight? They dont recommend a transmission cooler for driving with 4 passengers. The J30 only has a 1000lb tow capacity. Just wanted to bounce this off the forum.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
youll want to put a trans cooler in regardless!
B/M 70268 via summit racing.
robmcole
Car: 93 J30
elwesso wrote:youll want to put a trans cooler in regardless!
Is this cooler from Summit a direct connect (3/8 inch) for the factory cooling/heating hoses going to the radiator? Last, how much A/T fluid needs to be added to compensate for addition volume?
elwesso
2007 BMW M Coupe
robmcole wrote:1. Is this cooler from Summit a direct connect (3/8 inch) for the factory cooling/heating hoses going to the radiator? 2. Last, how much A/T fluid needs to be added to compensate for addition volume?
1. Yes2. Its a small amount, i just plugged it in dry, just let the car idle for a few mins before taking off for the first time.
robmcole
Car: 93 J30
Well if anyone ever wanted to see a trailer hitch on a J30, here it is!
DominickJ30
Car: 1993 Infiniti J30t
Looks like you will be replacing your transmission soon.
robmcole
Car: 93 J30
DominickJ30 wrote:Looks like you will be replacing your transmission soon.
Is the J30 transmission so horribly designed that it cannot handle the same weight of 4 people in the car?
elwesso
2007 BMW M Coupe
robmcole wrote:Is the J30 transmission so horribly designed that it cannot handle the same weight of 4 people in the car?
Dont worry about it..... youll be fine.
DominickJ30
I guess it really depends what you are towing. Dont try haulin a boat to the lake lol.
gr8scott72
Car: 1994 Infiniti J30t
DominickJ30 wrote:I guess it really depends what you are towing. Dont try haulin a boat to the lake lol.
He already mentioned what he'd be towing. I would think you'd be fine too as long as you're not taxing it out with more weight than mentioned or up big hills in overdrive.
elwesso
2007 BMW M Coupe
The main tihng you dont want to do is exceed a really big tonge weight, thats whats gonna cause things to start bending.....
