They tend to weight about 30 lbs (+/- a few lbs), and cost-wise you can get them as cheap as $55, so its not a major expense.
My bigger concern is what you describe, banging my knees and not being able to access the back area very well. The come as shallow as 20", so call it 2 ft from the back of the Rogue. Still, every weekend I have to load a cooler full of food, electric motor, battery, etc; things that tend to be heavy and not easily held at arms length. It may or may not be a problem, but its hard to judge without having one actually mounted on the truck.
There is a swing away model, but they are more expensive.
Pescakl1 wrote:If it is just to use it for the garbage, they are quite expensive garbage!!A good walk from time to time won't kill you (you go countryside for the fresh air and to exercise, right?).
If you find a good use for this kind of carrier, yes you can also use it for your garbage.
From what I understand, it will be about knee high (best height to annoy and hurt nicely), and put you about two-three feet away from the cargo door, so it will be in your way, for sure.How heavy is that thing?You will probably have to remove it, reinstall it each time you need to access the cargo area... or jump on it.
Good thing against brownnoser drivers!!
