Kompresshun »
https://forums.nicoclub.com/kompresshun-u133574.html
Fri Jun 13, 2014 5:18 am
Yeah G35's with that low of mileage go for a premium around here. That actually is a fair price considering what i've seen lately, because i've been looking at them too.
My sister in law just got an awesome deal on an '04 a couple of months ago, but it has 120k miles on it. She walked away with it for $7,000 though and it was a very well cared for car.
I'd post up in the G forums to get some better information from the actual owners, but the most common issue is them using oil. Basically some of them had an issue in the engine that caused them to use oil and it isn't a major deal if you keep a check on the oil, but it's something you need to check regularly if it's present because it can obviously cause an engine failure. It would be hard to tell at the time of purchase other than checking the oil to see if it's low, which it likely will not be. So if you buy it, basically just keep a check on the oil regularly.
