Traction TCS lights
Q45Viper
92 49 state Q, original owner, 130k. Since this car has been new I have periodically had the traction and slip lights come on, stay on for several days and then go off again. UNFORTUNATELY it would never demonstrate this malfunction to the dealer while it was under warranty, and yes it feels as if the TCS is turned off when this occurs. Well, I didn't have you guys back then but I do now. So they are on again as of today, anybody know why this happens and the potential fix?
Rex
Car: None
Did you see this post regarding it http://www.nissaninfiniticlub....22114
and Q45tech's reply within said link. Very detailed and may help point you in the right direction. Of course, I'm sure he'll be able to give you some additional info specific to your situation as soo as he sees it.
GEOFF
Car: CARS/BIKING
My '93 did the exact same thing and it was a relay underneath the battery that TEMPORARILY fixed the problem. When it did it again a few mos. later...they replaced the TCS motor under warranty.
csoluri92Q
Car: Wine Collecting and my burgundy 92 Q with forged 17 x 8 SSR wheels
Just replace BOTH relays under the battery tray. When I had the same problem, I replaced the TCS relay under the tray and it fixed the problem. However, the other relay failed a month later. My advice, go ahead and replace both while you are at it. They only cost about $12 from Joe T..........
Chris
