540sx »
https://forums.nicoclub.com/540sx-u66363.html
Tue Aug 19, 2008 9:04 pm
Q45 vlsd has the bigger axles of a 300zxtt and you just swap the diff cover , get the driver side axle from 300zxtt and the driver side axle from the q45 I can't remember which goes wear at the moment but there is a right up of this on this forum.you also need the hubs from a q45 or 300zxtt cause of the bigger axles.the Q45 diff is a r200 like the 240sx. you will want to either buy the oem rubber washers/ bushings or make your own like I did from some energy suspension onesfor the diff. I heard a guy is putting down 1200 whp with a 2jz in an s13 or s14 withthis setup.
So that is what I threw on my car cause I am installing a built 327 sbc with a turbo,keeping at low boost between 6-8 psifor around 600 flywheel hp.
you might want to consider changing your subframe bushings with nismo or solid aluminum.one nip sells ones that come with rubber washers and an install videothat was actually quite helpful.
good luck hope this is not too late.
