bradt »
https://forums.nicoclub.com/bradt-u39506.html
Mon Apr 20, 2009 5:36 am
First off, you seem a bit misguided in your quest for traction.
What purpose are you serving by negging out the rear camber? 1.5 degrees isn't too bad, but the closer to 0, the more contact patch you have.
The width of the tire is somewhat irrelevant. What compound is it? What brand? A 275 series s***ty tire is still a s***ty tire. Look at upgrading your rubber. This is probably the best thing to do for your traction woes.
A VLSD will not help you at all, especially with that power. The VLSD controls traction with a fluid "pouch" filled with viscous fluid. Once it heats up, it expands, locking the diff. This fluid CANNOT be changed out (easily anyway) and will not be up to the power. Not to mention, any VLSD hanging around these days will be worn out.
If I am not mistaken, the S15 diff still uses the R200 housing, meaning it will bolt right up.
