Didn’t see anything in the owner’s manual. I have searched the forum and Google and didn’t see anything that included all three issues simultaneously.
That makes sense. One issue I forgot to mention is when the backup camera is on the guide lines are off center. When you say scan the ABS, is that done with a basic OBD II scanner?VStar650CL wrote: ↑Sun Nov 20, 2022 8:35 pmSounds like maybe the Steering angle sensor, that would affect all three. Could also just be "past" DTC's if they cycled the ignition with something in the steering disconnected. You really need to scan the ABS and see what it tells you.
If the backup angles are off, that sounds like the steering angle sensor for sure.Big_Tone wrote: ↑Sun Nov 20, 2022 9:36 pmThat makes sense. One issue I forgot to mention is when the backup camera is on the guide lines are off center. When you say scan the ABS, is that done with a basic OBD II scanner?VStar650CL wrote: ↑Sun Nov 20, 2022 8:35 pmSounds like maybe the Steering angle sensor, that would affect all three. Could also just be "past" DTC's if they cycled the ignition with something in the steering disconnected. You really need to scan the ABS and see what it tells you.
