Traction control
Zachman54
Car: 2008 Infiniti G37S Coupe 6MT
One minor problem I have with my G37S is that the traction control is on all the time. If you turn it off the next time you start the car it resets to on and I have the remember the push the VTC button again. Does any one know if the can be changed so that the traction control will be set to off when you turn on the car and then you can push the button if you want it on instead of the other way around?
kmckis1029
Car: 2016 Q50 RS400 AWD
2010 G37x w/Prem, Nav, & Wood (sold)
2005 G35x w/Prem C (traded in)
i know you can buy modules for the g35... i think the company was called kptechnologies or something like that...
but its made that way on purpose... its on by default to protect the driver... you have to KNOWINGLY reach down and turn it off... so you know you are changing the Gs driving characteristics. that way you will never forget the VDC is off one day when its bad weather.
joe603
Car: 2014 Durango R/T
The VDC has an "off" button for snow (so you can get out of a parking spot by spinning your tires.)
Try these guys for the modules that defeat the OEM safety settings.
http://www.kptechnologies.com/...Coupe
Zachman54
Excellent, Traction control memory module $39. I fully understand why the switch is set to TC on. I just trust my own driving enough plus cant spin the wheels with it on.
